Starter question
belray
I have a 1987 200 hp black max and when I start it, sometimes the starter will engage for a second and then the gear disengages and the starter motor free wheels. It usually does this a couple of times and then the motor starts but it is happening more now. Do I have to replace the whole starter or just the bendix gear to fix this? Thanks in advance for your replys.
Dukedog
Put a touch of light machine oil on it till ya get a new bendix. Make sure tha start battery is up ta snuff.........
CharlieB
Clean all battery cable ends, bright and tight. Including the starter cable.
The drive rely s on inertia to 'throw' or 'screw' the drive up the starter shaft. You must have GOOD battery current to get it up and hold it there.
