thanks for the help!  i hope someone can help me, im stumpt!  i should state that i have been troubleshooting this motor and have eliminated most of the "shoulda thought of that" or "i screwed up and crossed a wire" stuff\clipart{biggrin}  any help would be appreciatted. the particulars, newer barr 5.7 gm in mercruiser setup. carb'd, thunderbolt type ignition.  new parts- starter, solenoid, slave solenoid, ignition switch, batt. cables.  all connections test out for proper continuity.  all wires in proper place by schmatics. ok that being said!  when the key is turned the engine will start but the starter doesnt disengage.  if the key is pulled back to the "acc" position the engine continues to crank until the key is put in the "off" position.  then starter will disengage and engine will shut down.  upon restart attempt the same thing happens.  im at wits end.  the only thing that seems odd is the orange lead that goes from the starter to the altenator has contstant power even with engine down and key in off position.  i also visually and meter tested all grounds for leaks.  what am i missing?  for the record this problem all started out of the blue with no warning, the engine ran fine then one day it got stupid!  thanks
