I have a 1989 200 Yamaha 25" shaft. On my latest trip of one week it developed starting problems. Sometimes while starting the voltage on the Voltage Meter @ the helm will drop to zero and I get a "click" from the engine, other than that nothing. Other times it starts immediatly, and still others the starter engages but only turns the engine approx 1/2 revolution. The last time used it would not start at all and I hand cranked it with a pull cord. Once started it ran great for remainder of trip, did not try to restart upon shut down.<br /> After getting the zero volts problem I tried the following "fixes". The parallel switch had no effect. I exchanged selenoids with the other engine and that did not help. Also changed batterie with other side to no avail. <br /> The boat is located in the Bahamas so local service is problematic at best. Any suggestions? Brett
