Starting procedure for a 1992 suzuki DT115
ogk57
Does any one know the correct starting procedure for a 92 Suzuki DT115
I just picked up a used boat and can't remember how to start it?
triumphrick
Re: Starting procedure for a 1992 suzuki DT115
How long since it has been run? Is there a water/fuel seperator that needs to be checked?
I would start with a fully charged battery. Squeeze up the bulb untill firm. Activate the choke. Advance the throttle only, make sure it is not in gear. Try starting but don't grind away at it. Just short bursts of no more than 6-8 seconds. Don't let it over-rev once it starts, bring the throttle back down a bit. You may have to "bump" the choke a few times if after starting it tries to cut out. Good luck! :)
country dave
make sure to push key in to choke before turning motor over
