Static Timing?
KScott78
Perhaps a stupid question, but could someone please explain to me; what is static timing?
thanks in advance for your help!
Nordin
Static timing is when you set the timing without running the engine. You set the points opening (if it is a points ignition system) to a fixed mark at flywheel or timingplate. If it is a trigger signal ignition system (most of the self-generating CDI system) to a fixed mark at timingplate or flywheel.
BUT the best way is to set the timing dynamic with a timinglamp to a fixed mark at flywheel at WOT. This method gives the correct setting and is does not matter what kind of ignition system the engine has.
KScott78
Ok thanks! For using a timing light, I believe that I my motor needs to be set to 28 degrees and there are several marks on the fly wheel. Would I need a timing light that is adjustable? Thanks again!
KScott78
Sorry, I should be more specific; I'm looking at the video in the sticky for link and sync: https://www.youtube.com/watch?v=UFhO5iBuTKs
he says to turn over the motor at WOT and use a timing light and set it to 28 degrees, for this I would need a timing light that can be set to the degree I'm looking for?
( hope this makes sence, timing is new to me ), thanks!
Nordin
Please what engine are we talking about? Hp, ignition system and if possible year.
You can use a timing light without adjustable degree.
The flywheel normaly has 2,3 or 4 marks (depending on ignition system) 0 dgr, 28 dgr, 30 dgr 32 dgr and 36.
If you can download pics it will help alot.
KScott78
It's a Force 1989 - 125HP - Model: 1254X9B, I believe it has 3 marks on it. Sorry, the boat is about 100km away right now. I'll be going up there this weekend to work on it.
Nordin
If it is a 125Hp 1989 it should have four marks on the flywheel.
The one that is alone (to the right counting in front of the engine) is 0 dgr then cw 28 dgr, 30 dgr and 32 dgr and it is refence to the pointer plate mark.
KScott78
Yes, I think you are correct. So I can do the timing at cranking speed with a regular timing light that is not adjustable? I just aim the light and it will light up the correct mark?
Nordin
Yes, if you set the throttle at WOT, put the timing light at #1 sparkplug and crank it with the starter is should light up at 28 dgr (number one mark to the left of 0 dgr mark).
28 dgr at cranking speed will give you 30 dgr with the engine running IF THE TIMING IS SET RIGHT.
KScott78
Perfect, this is exactly what I needed to know. Thank you very much for your help and patience!
KScott78
Thanks, Yes I saw that video and rigged up some wires to ground out the plugs and a jumper. Great vid, thanks!
