OldBoatGuy12
- May 11, 2006
- 31
Hello, my boat's(78 invader w/ evinrude 115) floor has rotted out. The transom is fine and the boat will only be run in fresh water lakes, no salt. I have gotten all the crap out and am at the point of where I am ready to put new stringers in and I came up with the idea of using a steel ladder-frame, much like those used in many race cars,in the place of individual wooden stringers. I would most likely use regular 1" or .75" .0625 wall square steel tubing. One reason for wanting to do this is that I have a pretty good engineering and CAD background and can design (and test for strength, weight, stiffness, etc...)a ladder frame system that will give a much better strength to weight ratio than the plywood that was originally in the boat. Another, is that I am by far a better metalworker than woodworker. And, heck, it might even end up being cheaper, although I don't know about that for sure.<br /><br />Obviously, rust becomes a problem instead of rot. However, I am pretty confident that a good paint or even powder coating will prevent this. As far as water getting into the tubes themselves, and eating them inside out: I can easily completely seal off any holes in the frames by welding caps on any open places. A good seal would be further checked by fitting an air valve temporarily to the structure, filling it with air, and putting it a tank check for leaks. Pretty fool proof. <br /><br />As far as attaching the structures to the hull, I would just glass them in like any ordinary wood stringer, except that only the bottom bar(which conforms to the hull) would be glassed. If I deem this unacceptable, I will most likely attach wide flanges to the bottom bar to give the resin more surface area to grab on to. Ideas here would be helpful. <br /><br />The idea is that since the frame shares distibution of ALL loads, it will result in a much stronger, much safer boat. Any and all comments or criticisms are welcome as I am sure I have not thought this out completely yet. If anyone needs to see a visual, just let me know and I'll send you a picture of my CAD renderings. Thanks!
