steering cable replacement
jrbohannon
I have a 1984 ranger 335v with a 115 merc tower of power. the hole in the back of the transom does not line up with the tube on motor. The rod is in a bind trying to push it through. Do i nee to remove tube or what. Thanks for any advise
Texasmark
Re: steering cable replacement
To not force the bend as you will kink the inner cable and ruin your cable. I bought a boat that the factory installer jammed the cable trying to do the same thing and it took me both hands to turn the wheel on a 90 hp engine. When I bought and installed my new cable, I found a different location so that I could have a smooth bend. Nice and smooth steering not.
However, if your problem is not that there is inadequate room for a smooth bend, but the cable is too long to get installed with the engine mounted, you will have to remove the engine from the transom, install the cable and then put the engine back on the transom. A rented engine hoist and a self made or borrowed adapter that screws on top of the crankshaft will work. I don't remember if engines of that era had lifting rings or not. If so, use them.
Mark
jrbohannon
thanks for the info. i was able to back the tube out a ways and the rod went right in.
