1989 regal medallion bow rider 3.7 merc cruser alpha 1
So yesterday while tubing all of a sudden I was not able to take sharp right turns..... I can take what I call a slow right turn.. I have looked for obstruction like a clamp or hose. I have looked for any obstruction inside and im not seeing anything. The long bar underneath seems to go all the way left but not all the way right.... If you look at the picture on the Inside you can see that when I turn all the way to the LEFT there is still a gap and that is the the amount I am missing I need for a right turn. So is it a rack issue ?
There should be 3 things I think in play Obstruction in the gimbal ( not seeing one) Steering cable or the rack getting stuck to the end of a right turn. Is there a wat to disconnect the rack from the what I call gimbal rod of shaft that goes from the steering rack to the gimbal. This way a way I can move the gimbal / lower unit all the way right or left an eliminate the gimbal as the problem and focus on the cable and rack. The pictures show a full right and full left turn so you can see the difference
