Steering rod and steering arm connection hits port side of engine well. Any Fixes?
Bubbasboat
After review, I realized I misstated the direction of turn. The photo is showing the motor in a full starboard turn, at least as full as it will turn, not a full port turn as previously stated
I just put a 1977 70 hp Evinrude on my 73/74 Glasspar V165 hull. When I turn wheel to port, the end of the steering arm and steering rod connection point hit the port side of engine well. Is there an adjustment in the steering that will resolve this? My previous motor did the same thing. It was an Evinrude as well. Same steering system as it was new 2 years ago. See photo.
GA_Boater
Re: Steering rod and steering arm connection hits port side of engine well. Any Fixe
Did both motors use the same arm? Maybe there is a shorter one so the cable can be moved more to stbd in the tilt tube? Tossing thoughts out.
17rogue70
it looks like the steering cable might not be centered before attaching to the steering rod. take the cable loose , turn wheel one way or the other to center and re attach. it looks as though the engine is center but the steering isn't. hope this helps
Bubbasboat
After review, I realized I misstated the direction of turn. The photo is showing the motor in a full starboard turn, at least as full as it will turn, not a full port turn as previously stated.
GA_Boater
Same difference. Try 17's centering first.
Bubbasboat
I corrected my post as I made a silly mistake and misstated the direction of turn. Photo is showing a full starboard turn, not port as previously stated. Sorry for the error! I will do as you suggest. Thanks
gm280
Two thing to measure to see if it will work either direction. Manually turn the engine to port and then measure the length to full starboard. Write that length down. Then do the exact same with the steering cable. If the steering cable doesn't have the same length as the OB, then all you can do is center them both in their mid ranges and install that way. Do the same even if the OB has a longer range as well. One way the OB will be the limiting factor and the other will be the steering limiting factor. But either way is the best you can expect from your setup...
Bubbasboat
Are you saying get the best balance I can get on the motor and cable combination, then live with the limitations of the engine well itself?
TD_Maker
You are definitely limited by the motor well with a push-pull cable system. You can always go to a retro-fitted hydraulic steering system. I do have a question though. Are you sure you have the correct steering arm installed?
Bubbasboat
How very interesting! I have the steering arm that came with the motor. How would I know?
TD_Maker
Willyclay
Thanks, "old school" is what us geezers do best. BTDT with installing push/pull cable steering in a 1970 Glastron V153. Am I the only one who thinks something is missing from the tilt tube in the OP's picture? I do not see any nut and/or wiper nut. How can that be?
Chinewalker
On the earlier Johnrudes, first generation with the tilt tube built in, the port-side nut was recessed in the mounting bracket.
How long is the steering rod that connects the cable to the motor? Doesn't look 100% kosher as there appears to be an extra bend in it.
Bubbasboat
The steering rod is 12" long. I looked at the steering rod again and there is a bend in it, but there is no evidence of it having been deliberately altered. Not sure what the purpose of a bend would be. It does not seem to cause any issue. I looked at the steering rod on the 74 115 hp Evinrude I removed and there is no bend in it and it is also 12". Mounts appear different, I'm guessing they are not compatible. Yes, the nut is recessed on the port side of tilt tube as you said.
Bubbasboat
Just as chinewalker said, it's recessed on the port side.
Willyclay
Thanks Chinewalker, great info. I looked at the parts diagram before I posted that but the recess was not apparent. Still learning after all these years!
boobie
If there's a # on that steering rod, post it.
Bubbasboat
I removed and cleaned steering rod with solvent and found only one marking on the rod. "T" . I am posting a couple photo's of steering rod. The rod is 12"
Now that the rod is removed and cleaned, it does appear there are marks where the bends are. Why would someone do this??
