95Bayliner
- Jul 13, 2011
- 59
I am in the process of obtaining all the components for a stereo system upgrade on my (you guessed it) 95' Bayliner 1800.
I'm pretty sure the existing stereo is the original as I find myself rummaging thru dusty boxes looking for my old mixtapes.
The current system only has 2 speakers, one of which does not work and the one that works, umm... sucks!
Decided it was due time for an upgrade.
So far I've purchased:
(1) Alpine CDE-102 H/U (18W RMS x 4)
(2) Polk Audio DB521 5.25 (45W RMS) Marine rated - These will be the front speakers
(2) Polk Audio DB691 6x9 (100W RMS) Marine rated - These will be the rear speakers
I am debating if a separate amp is needed to push enough juice to these speakers. I'm leaning towards - Yes. Does anyone think differently and why?
Any suggestions on the wattage in RMS I should be looking for on the amp? More importantly, does the amp have to be Marine rated? I plan on installing this deep into one of the cubby's under the dash on either the captain/passenger side. I don't think it will be exposed much sunlight or moisture. It stays pretty dry in there.
Will I need to do something with my battery to prevent it from dying while listening to tunes over a long period of time without the motor running? Should I invest in a second battery?
I've read that I should connect the RED (hot) and YELLOW (constant hot) wires from the H/U to an auxiliary switch on my dash to prevent battery drain while storing. I have two available, pretty sure they're not in use currently. Should I proceed with this direction?
Any other insight or knowledge is always welcomed and encouraged! I need all the help I can get.
