Silverbullet555
- Mar 13, 2011
- 621
Re: Stereo System replacement - Advice appreciated
Boats don't ground like cars which means you have to run a ground and power directly from the battery to the distribution blocks. So in answer to your question, yes, it is connected to battery - terminal.
Remember, you power and ground wires have to be of the same size. Many people think the ground doesn't matter, but it does.
Does the (-) terminal from the battery serve as the "main" into the input of the ground distribution block? Does it need to be grounded elsewhere?
Thanks for all the insight.
