Lou C
- Nov 10, 2002
- 13,865
If you can go on eBay and search for an original OMC Cobra owners/operators manual it explains exactly how to do it. These steps are also listed on a commercial website but I’m not allowed to post it here. The main points:
Block drain and poke hole
Manifold drain and poke hole
Disco big hose at the front cir pump let drain
Disco raw water intake hose at stat housing hold it down to drain water
Tilt drive up to make all 3 plugs on pivot housing visible remove plugs rod out holes tilt drive down to drain.
then put OMC gasket sealer on the plugs threads and replace. Put same stuff on block and manifold drain and replace. Take raw water hose hold it up and fill with -100 till it runs out water intakes on the drive, reconnect hose. Reconnect bottom end of big hose at front circ pump. Disco top end at stat housing and fill with AF till it comes out of the neck of the stat housing and then reconnect. No need to remove thermostat. Then disco the manifold feed hose at stat housing and fill with AF till it runs out the exhaust housing on the transom mount.
That’s it!
That’s it!
