still messing with the looper - fuel pump?
Dhadley
Re: still messing with the looper - fuel pump?
Sounds like you may have an air leak on that cylinder. Stick a toothpick in the idle jet on that carb to see if it picks up (make it rich to overcome the air leak). Remember, the front half of a looper is an X design. The lower left carb runs the lower right cylinder and so on.
tal
I'll give it a shot tomorrow. Funny thing is, I already checked for air leaks with carb cleaner. One place I did notice it took in carb cleaner was around the throttle butterfly shafts, but all the carbs sort of did this. I figured this was normal since there has to be a certain tolerance to allow the throttle shafts to rotate. When sprayed liberally with carb cleaner it did have an effect though.
Once I realized this I steered away from the shafts and sprayed around the bases of the carbs which yielded no change.
Dhadley
Check around the side plates on each carb body.
tal
Finally, a nice day that's not raining and freezing cold.
Here's what I got: If I stick the toothpick in the idle jet (small one) it will slow and bog down the engine. If I stick the toothpick in the intermediate jet (larger one) the engine runs smoothly without the huff or miss sound. Once I remove the toothpick from the intermediate jet, the rpms race up a bit then slow back down with the miss/huff. What does this mean? I'm about to pull the carb off and look inside. Not sure why the intermediate plugged would help the idle quality and not idle jet.
tal
fixed?
fixed?
Alright, I pulled that carb off, had a look at the little aluminum side plate that covers the low speed passages. It sort of looked a little warped like it could be leaking. I took it off and the plate itself seemed fairly straight. I pounded on it a bit to be sure it was straight but I don't think that accomplished anything. I ran a copper wire through all the holes again and blew air to be sure everything is clean. I replaced the carb bowl gasket with a new spare I had because it looked a little twisted and squished out in a couple places. I made sure not to over tighten and only make snug. Then I put the carb back on and fired it up in my little test trough. It was rough to get going but once it warmed up I was able to let it idle for 20+ minutes without any miss or huff.
Judging by the toothpick method I would assume the carb was pulling air through one of the gaskets I rearranged/replaced. I was able to turn my idle screw all the way in which resulted in an a perfectly smooth idle of around 900 rpms in my test trough. It does not provide full back pressure but is better than the water hose. I will readjust the idle the next time I have it in the water. So by the way it was idling yesterday it appears the problem is fixed but I'm not 100% confident in what I did to fix it.
