kcfromohio
- Jun 4, 2011
- 56
92 4.3 liter Alpha 1 regular cooling system...
First I replaced the thermostat. no help
Impeller was replaced over winter, but I pulled the intake hose off the water pump to see if I had flow from the lower unit. I had the ear muffs with water turned to medium. There was some water flow. I thought it was ample.
I replaced the engine water pump, still overheating.
I ran it with the thermostat out. no help.
Maybe it's not enough water coming from the impeller. Is there way to check?
I'm wondering if I may have a blockage in the block or the intake manifold?
Any suggestions???
Any suggestions???
