jerryjerry05
- May 7, 2008
- 18,183
You should start another thread about water in the drive.
There are 8 places were water can get in the 2 piece lower unit!!!
Remove the drive, drain, pressure test.
I use a mix of Dawn soap and water sprayed on the seals when adding compressed air
You don't need a lot of pressure to make it leak.
10# or less should do it.
I made a pressure tester from a bicycle pump.
