1981century
- Oct 5, 2011
- 22
I have had a 1981 Century boat with a 260 Mercruiser (350 GM) motor since 1990. The boat was a project with a frozen motor when I bought it. I completely rebuilt the motor and put all new manifolds on it when I bought the boat. I have thoroughly checked out all the typical things you would typically check in order to make sure there is nothing internally wrong with this motor. The problem is when you run this motor up to any kind of RPM, it stinks. It puts out a smell that is cross between rotten eggs, burning oil, and natural gas. I have checked compression, ran leak down tests with everything coming back pretty much normal. The engine runs strong.
I am beginning to wonder if I am missing something like a pcv valve or something. The motor has a round steel flame arrestor with two hoses that go to the valve covers. The factory hoses fit into the valve covers then go directly up to the flame arrestor. The ends of the hoses basically "direct" the funk toward the flame arrestor, but the carb doesn't really suck it all up. It smells so bad you can almost always smell it when you ride in the boat, although the motor does not leak or burn any oil. Have any of you had similar problems with a stinking motor like this and have a suggested fix?
