Re: Strange question about rim size....
The amount of increase in height will vary by tire profile and size. It depends on what size you had, and what size you are changing to.
Larger tires pull easier and ride smoother, carry more weight, turn slower thus create less bearing heat, and larger tires also are less likely to fail at higher speeds due to overheating.
I all but consider 8" tires a thing of the past, I won't buy any new trailer with 8" tires. The way I see it, 8" wheels were used back in the day to get the boat lower and easier to launch, today's trailers do that by design, not tire size.
I sort of look at 8" wheels as being more for local use than long distance, I've had all too many of them fail at highway speeds. The smaller tires seem to be ok when new, but after a few years and some dryrot, they're no longer reliable, far more likely to fail than a full size tire.
