Strange question about rim size....
norm45
Re: Strange question about rim size....
Since tires & wheels are being discussed here, I'd like an opinion on the following.
I have 2 sets of "D" rated boat trailer tires of the following sizes: 20.5X8.0X10 & another set that are 175/80/13. Both are high speed rated trailer tires & wheels. When mounted on the trailer they will be 88" apart measured from the center of the treds. My maximum weight will be no more then 2500#. Which would be the most preferred tire/wheel to use generally speaking?[/QUOTE]
For several of the reasons discussed in the preceeding posts in this thread, I would go with the 13" tires if it were me: larger diameter = less revolutions per mile which equates to less turns of the wheel bearing &, in my mind, reduces the heat build up/failure potential of the wheel bearings (provided they are properly maintained in the first place). Also-the 13" tire is easier to find in an emergency situation (in the middle of nowhere w/ a mom-n-pop tire shop as your only option on a sunday afternoon..)
mthieme
I agree. Bigger is better.
On the side of the tire you should find a weight rating as well.
Hopefully, the max load on the larger tire is greater.
reelfishin
.............. it seems every trailer I've ever seen on the side of the road had only one puny tire left on it.
I have to agree here, their always the ones with the trailer of rubber just behind the boat or the ones sitting there either propped up on a pile of firewood gathered from the roadside or nothing at all sitting in the asphalt with no spindle or hub left.
