2001 Volvo Penta 3.0 GS. Purchased the boat three years ago. Had the water circulating u-shaped hose burst a couple weeks back. Found there was a piece of an old impeller vane stuck in what looks to be some kind of restrictor device within the bypass cooling hose. Removed the vane and ran motor. I notice the replacement u-shaped water circulating hose is swelling a bit at idle and grows larger when increasing throttle. Unhooked the bypass hose, removed the strange restrictor device, reconnect, run engine. Water circulating hose no longer swelling at all regardless of throttle speed. Engine temp and all vitals look good. I’m thinking water circulating hose has been swelling since I got the boat, and once vane stuck in the restrictor hose pressure became overwhelming and burst.
Question is has anyone ever seen such a restrictor device in a bypass hose? Genuinely baffled as to what the purpose would be when it clearly causes enough pressure to swell circulating hose while operating. Restrictor looks pretty crudely made therefore doubt was from factory and can’t find it on any engine diagrams. I’m thinking I will just run the boat with it removed.
Pictures show swollen circulating hose at idle while restrictor device was in place, location of the restrictor device within the bypass hose, and some pictures of the restrictor device once removed from bypass hose.
Interested in any information on this. Thanks.
