Strange whining noise from the port side of my inboard mercruiser 5.7. PLEASE HELP!!
mrijeff
Any help on this would be greatly appreciated. I can hear the whining from the port side of the engine itself. I cant localize it exactly, and it seems to be somewhat intermittent. It sounds almost like the trim motor keeps running after trim is stopped. Has anyone ever experienced this? Its a 1997 Sea Ray 210 BR. 5.7 Merc with Alpha 1 outdrive.
Re: Strange whining noise from the port side of my inboard mercruiser 5.7. PLEASE HE
Ayuh,... Check the P/S fluid level, 'n belt tension...
That's 'bout the only thing on the portside that can whine...
mrijeff
Thanks for the advice. I didnt even think of the power stering pump. Ill check it out Bond-o.
Don S
Is your engine EFI?
mrijeff
Yes it is EFI.
Don S
You have an electric fuel pump and cooler in that black box behind the port motor mount.
mrijeff
Thanks I'll certainly check that too.
Don S
When you first turn the key to the run position (Not start) you should hear the pump come on for 2 seconds and shut off. If you do, is that the sound you hear?
mrijeff
No its louder than that. You can hear it with the sun lounge closed.
