- Oct 25, 2011
- 25,210
Re: Stratos 1850 possible rebuild?
If so, I'd run w/ it. If only to save the time & etc to plane it. I think GT had to kerf the wood to get it to follow the contour of the hull. Esp along the port side where he's got those 4 or 5 spring clamps
Once installed, cove the bottom as you would any hull-wood union & layup some resin & glass.
Colors aren't my forte, that's the Admiral's domain
Do you have room for the 3/4"?Advice needed.
What kind of wood is acceptable to use for the rub rail screws? The ply that is in there now are 6" long or so and 1/2" thick and I believe that it is cedar. Many of the holes are also stripped out so I want to replace the wood. I have plenty of 3/4" exterior grade that I can plane down to 1/2. Will that suffice?
