Woodonglass
- Dec 29, 2009
- 25,930
Re: stringer questions
Is this the resin you have? If so, then it is fine for All of your restoration needs. How much are you paying per gallon? uscomposites in Florida sells a good laminating resin for $25 bucks a gallon. Plywood is good as long as it's exterior grade (it uses waterproof glue). Don't use interior/cabinet grade. It looks nice but uses non waterproof glue. Check the first link in my signature below for some good info on what you will be doing.
