stringers and sole
1cobia
Can I use epoxy on stringers and to set sole on, and then polyester top side so I can gelcoat the cockpit ?
Re: stringers and sole
Ayuh,.... Sure, Why Not,..??
1cobia
Just thought epoxy would have a stonger bond on the stringers to the hull
is that overkill ?
ondarvr
While occasionally a stringer does come loose from a hull, its normally from smashing into something at a very high speed, or from poor workmanship. Of the millions of boats made with polyester over the years comparatively few have fallen apart, so its not really something to stress over. It won't really make a difference which one you use, but if you start with one type, use it for the whole project.
