f_inscreenname
- Aug 23, 2001
- 2,591
Thanks to a friend I now have a strut to work with for the race boat. This one is about as close as it gets off the (very old) shelf. But as you can see from the pictures it’s not a perfect fit. That leads me to a question or two on how to go about making it work.
1, How close to the prop should this strut sit? The old strut used to ride about an inch off the prop. I ask this because …
2, Can I move the strut forward, up the prop shaft? Like 2 or 3 inches? If that’s the case I can fix the existing cut out and move the strut forward on the shaft so I can counter sink it into the hull. It will still need some sort of spacer built due to the angle not being standard. You can tell by the smaller strut in the picture below. See how the side closer to the prop hangs down lower. I guess that is a racer trick.
3, Last but not least if nothing else will work and I have to have the strut as close as possible to the prop can I build something that will fill in the gap between the strut and hull? I used to have a boat that had a old depth finder sender on a little wedge (shaped like a little boat) so the sender would point straight down. The boat did 50mph and it held on for decades.
http://www.supernova19.com/forumcw/index.php?topic=1127.msg7373#msg7373
