Stuck at the finish line - pre-alpha drive install
wca_tim
Re: Stuck at the finish line - pre-alpha drive install
Little epilogue here.
Tonight I summoned up my courage and took some aspirin, then tried again to mount the drive. I re-checked the alignment (good) cleaned off the input shaft splines, applied some fresh all-purpose grease and oiled the O-rings on the shaft.
After all that it went in on the second try, pushing with my shoulder behind the upper half of the unit.
:p:D:D
So now on to my next problem... adjusting the new lower shift cable.
Erik
if you got the length right when you installed it, it'll be straight forward.
