ct1762@gmail.com
Ensign
- Jan 17, 2019
- 955
no 170v is plenty. ususally one or two cylinders is off by 20-30v.check the condition of the primary terminal metal on the end. might have some corrosion. i'd be suspicious of the sensor coil next. did you test resistance of the orange wires from the pack? they should all be relatively even... 85-150 ohms depending on the meter. disconnet the rectifier yellow wires and see if it clears. if it does, replace rectifier. if it was bad, just another reason to check the sensor coil. might have fried the old stator, too. any burning/bubbling on the old one?
