Sunk Boat
ondarvr
Re: Sunk Boat
Get to work on the motor immediately, no delays.
ebry710
Ensign
Re: Sunk Boat
I wonder if you can get an old large truck inter tube and some how stick it in the boat or under it and inflates it to help lifting it up good luck
Did this once. Worked great. Of course we have scuba gear and a spare tank to fill the tubes. Took a couple hours. We had fun doing it.
Once up we towed it to the ramp, unplugged it and got it up on the trailer.
Tashasdaddy has the rest.
redone4x4
Re: Sunk Boat
glad u got it back. cant wait to see the pics though, sounds interesting.
Chris1956
Re: Sunk Boat
When my speed boat sunk, I used a jet ski winch bolted to the dock piling, connected to both the stern eyes to pull the transom just above the water line. Then toss a pump into it and wait for it to float. You only need to raise it an inch or so above the surface, and you can pump it out.
That looks like a fairly seaworthy boat. How did waves on a lake sink it?
drew2302
Re: Sunk Boat
What we did was get the boat up to shore wait for the tide to go out. then when the boat was above the water line we pumped it out.
Maclin
Re: Sunk Boat
Glad you got it home.
Just for future reference and for others that may see this, for smaller (14-18ft or so) trailered boats, getting it towed back to the ramp and putting the trailer in deep (that is the trick, may need a different vehicle than original, or even extend from the vehicle with vary sturdy ropes/chains) then lining it up and hooking the winch strap up is a start. Know your ramp, try like heck to not let the trailer tires go past the end of it. Get the keel trying to come up over the first roller and see how far it will go. Take the plug out, it does not matter now but will if you can get the boat on the trailer some and get it to want to come on up the ramp. Leave the plug out and pull the boat up a little at a time, the idea is to get the level of the water in the boat slightly higher than the level of the lake and let the water exit thru the drain plug hole. Takes a while but if you do not have any pumps around this works. The boat will be extremely heavy with the water in it, slow movements and time are your friends. I have seen this work a couple of times at the small lake I frequent.
As others have said it is critical to work on the engine as soon as possible to minimize corrosion damage.
DEBBIE DAVIS
Re: Sunk Boat
I don't know where to start. Yesterday my son and friends were on Lake Conroe in Texas. It became very windy and they couldn't make it back to the ramp and their 18' bass boat sunk. I picked them up last night and they were OK, thank God. The back half of the boat is submerged. I have a 19' Monterey and we are going to attempt to rescue the boat today. Any suggestions would be greatly appreciated. Love the website. I will post pics of this fiasco when we are done.
Thanks, Randy
Am so sorry to hear about your boat but am VERY happy that the boys are okay. We were out yesterday and saw the submerged boat along with the emergency vehicles. I have a small clip/video on my cell/Facebook account if you want it. Don't see a way to post it here or I would. I have been searching the net off and on most of the day HOPING to hear that the people on board were okay. Again, so sorry to hear about the boat but SO happy that you still have those boys to hug!!! Best of luck with the boat...I feel for you!
thepotroast
Re: Sunk Boat
Are you related to the OP and/or story? Different screen names....just curious if the story turned out this way or not? :confused:
freeisforme
Re: Sunk Boat
I have been involved in raising three boats over the years, one was a smaller runabout, with an outboard, which sunk in shallow water, bow still afloat. What we did was put two large tractor tubes around the outboard's lower unit, and stuffed two more into two rear compartments then inflated them with a portable compressor. The boat floated, of the bottom well enough to bring it closer to shore, we then pumped out the water enough to tow it back to the ramp. On that run, someone rode in the boat and reached back and pulled the drain plug while underway, at this point, I kicked up the speed a bit. This drained out 90% of the water remaining. While underway, the guy in the boat also did a makeshift repair on the broken livewell fill tube which is what caused it to sink.
The second one we did was a sunken cuddy cabin, in a river, about 5' down, completely submerged. It was an older boat with no flotation. We took advantage of the fact that it had a cabin to raise the boat. We were able to stuff several large tubes and inflatables into the cabin and fill them from the surface. Only one guy had to get wet, the guy who had to keep swapping over the compressor hose to various tubes. The boat started to rise as soon as the second large inner tube was inflated, when we filled the third one, the boat was at the surface, and was boardable. We tried to pump it out but the leaks were too severe. It was an I/O boat that had had lost its exhaust bellows. We again, towed the boat, pulled the plug, and kept it moving all the way back to the ramp where we all but beached it while we slowly winched it out letting it drain.
The third one was a smaller aluminum runabout, which was half sunk and pretty waterlogged, it was an abandoned boat left for years far from any ramp. We tore out all the soggy wood and interior, bucket bailed it as best we could and towed it afloat with the plug out all the way back to the ramp and a waiting trailer.
David Greer
Re: Sunk Boat
There are 2 strategies on the inner tubes: one is to float the boat, esp. the stern to keep new water out; the other is to displace water inside the boat to help whatever bouancy it has.
Be careful around a swamped boat if it's not on the bottom; it will roll without warning and once it starts you can't stop it. Working in a swamped boat is like riding a unicycle.
Borrow or rent a big thrash pump from a construction equipment company to suck it dry.
One of the best ways to stop a hull leak is to lay a piece of tarp across the hull from the outside; the waterpressure will hold it in place.
I'm carrying plugs for each of my through-hull holes just in case, as well as spare fittings. Also rigging an extra bilge pump. Redundancy, my boys, is the best defense.
grego
Re: Sunk Boat
My father told me tale,alot like this. He said, they pulled a boat on either side of half sunk boat, tied off to front cleats, and pulled on rear to get motor out of mud, then tied off and Then started moving forward. the water cleared the top rail and he said that if someone could have removed the drain plug, the boat would have been floating on it's own by the time they got it to dock. Makes sense to me! I think you would have to replace plug before you stopped moving forward.
BWR1953
Re: Sunk Boat
So how did it end? Nobleracing hasn't replied with the story or pix yet.
stackz
Master Chief Petty Officer
Re: Sunk Boat
sank my boat 2 years ago in salt water. it was down 15 minutes and got towed up and out by a parasailing boat.
they even tried cranking it :(
thank god its a 2 stroke.
got it home that day and drained the gas tank (it was half full of water) the carbs got drained, each was full, the starter was full and got drained. the plugs were pulled and the engine turned over.
then fresh gas and cranked it up. ran just fine but water pump and thermostat were toast. had to break the crank free and the starter free the next few days while we ran it.
let it sit for 2 years and replaced the starter/rectifier/waterpump/thermostat and it cranked up and runs just fine.
though the steering locked up and had to be cut out and replaced as well.
at least yours went down in fresh water...
grego
Re: Sunk Boat
Just an idea! We kept the water tubes from my brothers old waterbed, the one that had, like 6 or more tubes. Why? " I don't know?" but seems to me that with a little modding and a cheap 12v air compressor, the 6 or 7ft tubes could lift about any boat to surface and be very stable doing it. I will have to look through storage unit and find them and put them "modded" on board. You just never know, when or IF needed. OR! Here is a no brainer! Instead of throwing away all of that styrofoam packing, you get when buying just about anything, pack it into burlap bags and secure it in the holds of boat. Out of sight ,out of mind, and keeps boat afloat! MY 0.2
