surge brakes
bjm1310
I have a 2003 Prestige trailer, when towing the wheels become very hot. Have cleaned master cylinder, bleed the calapers, the pads are good and the calapers are clean and free to move. The trailer seems to keep pressure in the system even when brakes not be applied. Help before I loose a wheel bearing
RIDEPATE
Re: surge brakes
I'd guess you've either got a bad-line or a failing actuator. How does it act when you use the lock-out for reverse??
burp
Re: surge brakes
Look at the brake caliper......If it has an "R" on it as in the attached picture, most likely the caliper puck has corroded and thus won't fully retract when the brakes are released. Prestige changed over to Kodiak calipers to eliminate this problem. Since Prestige Trailers is no longer in business you should contact Heritage Trailers. http://www.heritagetrailers.com/contact.htm They have knowledge of the trailers Prestige built and should be able to help. The biggest task to convert from the Reliable calipers to the Kodiak calipers is that the caliper mounting bracket is slightly different. To remove the Reliable bracket requires the hub/rotor to be removed from the axle or the use of a cutting torch. I replaced 2 calipers before switching over to the Kodiak calipers which I purchased through Prestige. Six years later....no further problems.
bjm1310
Re: surge brakes
The last few boat trips i have ran with the brakes pinned to see if the heating problem goes away. The heat is still there. Looks like the brakes ingage but will not releace
bjm1310
Re: surge brakes
Did the new calapers come with new brackets ore did u modify the old ones. I have torches available and can do the work needed to change the calapers. Not aire what needs to be done. Thank-you for the infoe
bruceb58
Re: surge brakes
You either have a drum brake master cylinder or there is some debris that is not allowing the pressure to be relieved. Do you have a backup solenoid on this? They are susceptible to getting clogged with a very samll piece of debris.
burp
Re: surge brakes
bjm 1310
New calipers with new mounting brackets. Check your inbox for a PM.
bjm1310
Re: surge brakes
I plan to call the company today to get the new parts.
Will let u know how it all works out.
