hi,<br /> i've just purchased a used 1997 suzuki dt2.2 outboard privately. it ran good on my lake but when i went on a fishing trip, it acted up! the symptom's are:<br />1- at idle, the engine seems to be knocking(kicking) and the steering is not staying put(yes, i did tightened the shaft). <br />2- when revving up to a higher speed, you could hear the sound pitch change(fluctuating) on it's own.<br /><br />the thing i've noticed was the shear pin on the prop was broken and i replaced it before the fishing trip but the prop is somewhat loose even with a new shear pin. the old pin did some wearing on the prop. the question is, could a loose prop be doing my above symptom's?
