Suzuki DF 25
tman554
My DF25 will not run anything below medium throttle. I was having this problem before, so I just removed the three carbs, cleaned them (they were full of jelly), replaced the gaskets, o-rings, needle valvle, etc. it does not seem to have fixed a thing! what gives!
lakensea
Re: Suzuki DF 25
Did you sync the carbs?
tman554
Re: Suzuki DF 25
No. When I read the directions, it sounds like I need the thing to idle in order to sync the carbs. Right now I can barely keep the thing running.
tman554
Re: Suzuki DF 25
drill out the EPA jets? I don't even know what that means. I certainly did not drill anything!
I did remove all the jets that the manual instructed, sprayed them with cleaner and wiped them down. I did the same with the carb body.
reeldutch
Re: Suzuki DF 25
the DF25 are emision tested in the factory and set.
than they put a tamper proof plug in it so its not adjustable. thanks to the EPA.
