Suzuki DF225 Pinion Gear source
frustratedboater
I have a friends 2010 Suzuki DF225TXX lower unit that I'm rebuilding for him. It was pretty bad with some salt corrosion and the case had a crack by the hub. Through this process I had discovered that the pinion gear is cracked and looking to replace it and the pinion bearing as well. Is there a source that only sells the gear and not the kit of all three gears?
I doubt you can find just the pinion.-----These are installed as MATCHED sets.
