Suzuki DF6 thermostat
dan-polarka
Where is the thermostat? Please help. I never had Suzuki before, cooling water is comming out but the engine overheats. Impeler OK. I could not find thermostat, I bought the engine without manual. Thanks for any help.
lakensea
Re: Suzuki DF6 thermostat
Remove the intake manifold and you will see it.
dan-polarka
Thank you guys. It helped, but only for about 20 minute full run. Now it OVERHEATS AGAIN even if water coming out under the head is very strong. (I removed the termostat comletely). It is overheating even in low RPM or idle.
