Motor was winterized and was in storage 1 year. On start up with flush kit the water stream from the tell tale was a normal stream. After a few minutes over heat alarm sounded and I shut it down. I removed engine cover and after a few minutes re started. Water is leaking on front lower area of engine behind the fuel injection unit where there is a flat rectangular cover plate and a small metal tube having a rubber hose connected to this tube. I have never seen water leaking here before. Engine is a 1997 model and has only 200 hours on it. What could be the problem? And is $82.00 per hour an acceptable hourly labor rate at a Suzuki dealer?<br />Thanks, Bunkie
