reggienaldo
- Feb 11, 2006
- 5
My bro & I bought this motor used and the guy said it ran great but the carbs probably needed cleaning.<br /><br />We were a very eager to see if this thing would run and used starting fluid to get her going. I know we should have used fuel mixture, I will get a spray bottle for next time.<br /><br />Eventually it would Idle pretty well, and It sounded very strong when at high rpm's, but we had to play around with the choke and the throttle to keep it running. When it was put into gear it just stalled. The red oil light on the front was flickering on and off a bit.<br /><br />Do I need to buy 3 carb Kits?<br /><br />How can I make sure the oil is OK?<br /><br />What should I tell my brother if he starts trying to fire it up without checking this out? Are we going to destroy this thing?<br /><br /><br />Thanks
