glenngamblin1
- May 20, 2004
- 6
I am working on a suzuki DT 75. I believe it is about a 92 model. Any way, a friend brought it to me for a simple carburetor job, so I acid dipped the carbs and thoroughly cleaned them, and installed new carb kits. When I started it, it ran great for a few minutes when I noticed that it wasn't getting water through it. I then replaced the impeller but it still didn't get water, so I pulled the thermostat cover off and it shot water over the engine, and it died. The ignition is firing, it is getting fuel, but it will not start. I noticed that the fuel was premixed so I flushed it and put fresh fuel in it. Compression is 115 pounds in all cylinders, and it still won't start even when I spray fogging oil in it. The plugs have also been replaced, ngk b8hs. Please give me some pointers.
