I'm in the process of trying to replace the water pump impeller in my '78 DT25. I've removed the prop shaft, disconnected the shift rod, and snap ring/pinion from driveshaft. The bottom of the lower unit (black section) will drop about 1/2 ", but it seems that the driveshaft is preventing anymore movement. It is not moving when I drop the black section.
I removed the four bolts (of course one broke off) that hold the next section (silver), but it doesn't want to budge. I can't see any other access panels that would allow me to disconnect any driveshaft coupler or pin. Is this just stuck tight from the gasket or RTV sealer, or am I missing something? I was whacking pretty hard with a mallet and block of wood, but it's not budging, and I didn't want to start driving a pry bar between the sections if I am missing another fastener, and I don't want to crack the housing.
When I drop the black section, I can see the lower part of the water pump assembly, so I'm sure I have to drop the silver section to get to the top of the water pump and to get the impeller off. I have a manual but it doesn't have any specifics or even mention this two part lower unit, and the pictures look like the entire unit is off with the driveshaft and waterpump tube still attached.
Any suggestions would be very helpful. Thanks!
