Re: SUZUKI DT55 Clutch Rod/Shifter Pulled Out
Possibly he means the cross shaft at the top, the one you have to push back in order to drop the lower. I just went through something similar on my DT-85. It's tough to see what you are doing with such limited access and visibility. I used some long forceps to pull the rod back through. Mybe he can do something similar. If he does indeed mean the shift rod, that's a whole 'nother ballgame !!!!
