Hello everyone. Thanks for taking the time to read this. I am trying to fix this DT55. It idles very poorly and stalls out. Also runs rough at higher RPM's as well. The problem does not seem to be fuel related as chokeing any of the carbs, or all of them does not help. I tried a different fuel tank and line as well. The plugs are new and it ran the same with the old plugs. I don't know the history on this unit as it was purchased at an auction and as far as I know has never idled correctly. Is there something common to fail in the ignition? I have read all the threads on this board and have not had any luck yet. I pulled the flywheel and checked the key and it is good. I am going to pick up a manual to check out the triggers and coils. Any other ideas?
