Swap aq231a for 200d?
jalmashy
I have an aq231a chevy with Volvo stern and rings are bad. I was wondering if I could switch it with a 200d Volvo engine and how much trouble it would be. The new engine is ready to drop in for $500. What ya think
RogersJetboat454
Re: Swap aq231a for 200d?
If your willing to accept the drop in performance, and having to possibly do a little mixing and matching because the design/location of the parts and pieces have changed, then by all means.
The biggest hurtle may be a flywheel if the 200D doesn't come equipped with one. As per the VP website, it appears the 200D has a 2 piece rear main seal, where as the 231A has a 1 piece rear main seal. If the 200D comes with a flywheel, then you should be OK. If not, then you will most likely need to find one as the 2 piece, and 1 piece RMS flywheels won't interchange. If there is a difference in flywheel diameter, then the correct marine grade starter will need to be swapped in as well.
If the 200D was a saltwater job, I would be going over it with a fine tooth comb to make sure it's not rotten, and new manifolds/risers would be mandatory. Just make sure your not getting into an engine that's no different, or right behind your current engine. If you could do a compression test, check the oil pressure, and listen to the 200D, that would be the best thing.
jalmashy
The guy says it still has bell housing and everything on it, and he didnt remove anything from it. Im just wanting something to get by with until I can have my original rebuilt this winter.
