1970kayhydro
- Sep 3, 2008
- 199
I have a 1971 40hp johnson longshaft and I need it shortshafted. I recently came by a 1958 35hp johnson shortshaft. I pulled both lower units and they look the same besides a few things. The 58 prop shaft has a threaded end and the prop nut is metal and threads on. They both have the cotter pin holes but the 40hp has a plastic prop nut. Will this work? Would the gearing be different? The bolt holes are all in the right spot and the shaft ends are the same. Here are some pics.. Any advice is greatly appreciated!!
