Re: switch a jet to a prop. lower unit?
Switching out a lower unit from jet to prop should be no problem.
But......
As I have seen on some boats when switched over to a jet the transom height becomes an issue and is adjusted accordingly.
If your boat has a standard transom height I don't see much of a problem.
Ditto here - if the jet unit was added "after market" and the engine itself has all the parts necessary for neutral and reverse.
IF it was a factory built jet, although the jet unit is the same as aftermarket, but the engine itself might *(I say MIGHT - you have to check) not have the parts to have a reverse or even a neutral gear in a conventional lower unit.
As you know, with a jet lower unit, the engine always operates in forward, even when in "neutral" and reverse. Reverse is simply the reverse-boot device cupping over the jet outlet and directing the output forward, and "neutral" is simply adjusting that boot so that it balances between forward and reverse, neutral in the water, but not neutral at the drive shaft.
In general a "factory jet" will have the jet unit painted the same color as the engine (i.e. Mercury Black). The after market jets are usually red in color. There are exceptions to this rule though - AND, factory jet doesn't necessarily mean the reverse and neutral capability isn't there, but you have to check.
