Gus Mortimer
- Mar 10, 2004
- 109
I just discovered my motor (82 90 L6) is only running on three cylinders. <br /> I have never had this motor in the water. I have done the water pump impeller and the carbs. but it was still running rough. after pulling a plug to see if it was missing I found that three cylinders are not firing, now I havent checked the stator or trigger yet but am about to. <br /> the three that are not firing are all fed from the same switch box so I almost just went and bought one...
- <br />
- Is it more common for a stator to go bad or a switch box?? do these just go out?<br /> If it is the switch box what could have caused this? could it just be a bad wire connection?<br />
