Switch box testing
Capt dave 258
Greetings. I have a 1988 Mercury in line six cylinder, 115hp. Can someone direct me to a site that shows how to test the switch box for this motor? This particular motor has 2 switch boxes. Thanks
All the IL6 motors with ADI ignition have 2 switchboxes. Try the CDI electronics web site. They used to have a switchbox test.
In addition to the 2 switchboxes, your motor has 3 triggers, and two stator charge coils, one for low speed and the other for high speed operation.
What cylinders are not firing?
Faztbullet
There is only testing for output so make sure you have a DVA adapter and if problem found only use OEM,Serria, Rapair/CDI or WSM replacements. The cheap stuff of Amazon is junk
