Switching from Johnson to Mercury
Buster_boy
My 16ft pontoon has a 40hp Johnson installed from manuf. I may decide to remove it and install a Merc 9.9hp instead, making it a restricted Water boat. How difficult is it to switch the ignition and controls from Johnson to Merc? I know I'll need top mount Merc controls, but what else?
I'm not a complete idiot, just a half of one, and some things are better left to the pros. Is this one of them or can I do this myself in a weekend?
ondarvr
Very simple switch, remove the motor and all the Johnson controls, then mount the Merc and its controls.
Yegboats
Assuming you're going to go with a new Merc 9.9 0R052327 serial number and above. (w integral trim)
1x Console mount control (top mount) 8m0059686
2x Mercury gen II cables 897978aXX length tbd
1x 84-896537TXX (T15') (T20') (T24') engine ignition/choke harness length tbd
1x 87-88107a13 key switch assy with choke
1x 84-896541T01 Adapter harness ( The large round end with 14 female holes receives the 14 male pins from 84-896537txx which lets you plug it to your engines white power plug"engine amp connector")
Instrumentation you may consider
1x 84-892990t01 Analog gauge harness
1x 6k tach 79-895283axx (a03) (a23) black/white gauges
If you don't want gauges you can probably save some money by going this route
​1x Ignition/Choke Assembly 8166266AXX (20') (A24')
1X Adapter Harness 84-892473a01 <~~ this harness is an 8 hole female harness that receives the 8 male prongs from the ignition/choke assy so it can plug in to your engine
Buster_boy
Yes - it's actually OR014E559 so it looks like it's newer than what you listed. I'm using it now as a kicker to the Johnson. I'm using Quicksilver side mount controls/ignition for the Merc. If I can find a Merc top mount, can I strip the side mount apart and use those parts (throttle/shift cables and electrical).
