SX-M Drain Hole
GMK35
Can anyone confirm the SX-M drain plug hole size/pitch? Looking for a good gear lube pump that’ll fit it for gear oil changes, but am seeing a lot of competing statements on Amazon and other sites. They all say 3/8-16, but some say fits Volvo and others say specifically does not fit Penta SX. Also, if you have a good rec on a pump you use for this application, I’m all ears. Thanks!
kenny nunez
Just remove the dip stick and try a 3/8” 16 bolt. If it screws in easy then the drain will be the same.
GMK35
Only downside is I do that and then have to wait to finish the job/can’t use boat anymore until ordering the right thing. But, that is my backup plan if nobody knows the answer.
Ayuh,..... Welcome Aboard,...... 3/8" 16 it is,.....
