Re: Synthetic oil
The chart was never meant to be linear. Look at it again, there is no upper, or lower limit. If you boat in 100° weather, and wish to use a single grade oil, then you would use the 40W. Yes, there is a narrow band of where 30W should be used, but that only means Merc found the other weights worked better at over 50° or under 32°.
