system check tach question
ewade1601
'97 Evinrude 90hp
VRO system removed by previous owner.
Check engine light stays on.
Other lights come on randomly, in sequence, and go back off.
Tech @ shop says the unit is bad and needs replaced.
do I replace it with the same part or do i need something different because of
the VRO being removed? No issues with motor, runs like a champ.
thanks in advance for any help.
ewade1601
will the 'standard' tach just plug in to the system check harness? will i need to install temp gauge seperately ?
will the alarm still work?
Chris1956
Engines of that vintage should have the system check tachometer DIP plugs plus ring terminals for the black, purple and grey leads to a standard tachometer. You might take a look for those, under the dashboard.
