On the extra long 25" shaft version of the T9.9 there is a spacer of about 2.75" on the top of the lower unit. To remove the water pump housing this must also be removed. It seems firmly attached but I don't see any bolts. Any trick to removing this?
Thanks in advance!
Thanks in advance!
