hookinfinger
- Jul 31, 2003
- 6
Hi everyone !<br /><br />I recently had a tach installed on my boat.<br />The boat is a 1990 15' Boston Whaler with a 1990 Johnson 70hp VRO engine.<br /><br />The first time I used the boat after the tach was installed and shut the engine down I noticed the needle was pointing at 1000 rpm instead of zero.<br /><br />I started the motor back up at which time the needle would move to about 900 rpm , however there was no fluctuation of the needle.<br /><br />I tried this engine off and on procedure several times, yet when I shut down the needle would go back to reading 1000 rpm.<br /><br />I tapped and then rapped on the tack trying to un-stick it with no luck.<br /><br />I called the mechanic who installed it and was told not to worry that it will work fine while I am under way.<br /><br />Even I , who knows nothing about these matters would think there is a zero on the tach for a reason and certainly the needle should be bouncing around a bit while I am at idle.<br /><br />So finally my question(s): Do you think I have a faulty tach ? Can this problem be fixed with an adjustment to the tach ?<br /><br />Your advice would be greatly appreciated !<br /><br /> Regards, Dennis
