metriccrescentwrench
- Oct 22, 2007
- 2,598
I want to add a tachometer to my recently purchased boat.
In outboard terminology is "12 Poles" the same as "12 Pulses"? What will I need for my motor?
On the 3 pinned plug that's beneath the throttle friction lock, it's got the purple hot wire on it but not the grey tach signal or the ground. I can probably locate pins that will fit the plug but need to know which signal wire goes to which position.
thanks
thanks
